df 7110 stapling limit
+ More Options
Posts
  • n25an
    • Jul 2008
    • 1030
    legal size pages stapling limit is 30...
    I am checking if there is a firmware fix for this...
    or a setting change I can make that can affect this...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    Re: df 7110 stapling limit
    what are you trying to do? increase the stack that can be stapled? That is dependent on the staple unit itself.
    • n25an
      • Jul 2008
      • 1030
      I am trying to find out if this is a hard and fast rule or if there is some kind off special firmware that kyocera has that can change it... and yes I am trying to increase the stack size for stapling for legal to about 50...
      • Santander
        • May 2009
        • 768
        To the best of my knowledge this is a hard and fast rule embedded in the firmware for both legal and ledger sizes. It is not a function of stapling the larger stack size as stapling 50 sheets of 20 lb. letter size would be the same as stapling 50 sheets of 20 lb. legal. I think it has more to do with Kyo thinking that outputting the increased stack size for legal/ledger would create more errors in the finisher. It does not make any sense no matter which way you look at it, but I have found no way to work around it.
        • n25an
          • Jul 2008
          • 1030
          thats what I needed to know
          thanks...
