Taskalfa 3501 external meter/ counter
  • patrickjlc
    • Feb 2015
    • 212
    Is there a way to install an external meter/counter on the 3501? I had taskalfa 420i/520i and the older 4050/5050 had a plug where one could tap an external counter and switch.
    Is there such option on the 3501?
    Thanks.
    Sent from my SM-G930V using Tapatalk
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Re: Taskalfa 3501 external meter/ counter
    Thanks.
    are you talking about something like a hethcon or credit card style to allow users t operate the unit? what is the purpose on the external meter that you want to use it for?
    • patrickjlc
      • Feb 2015
      • 212
      Yes, like a coin op.
      • Santander
        • May 2009
        • 768
        If you are referring to a key counter where the user has to insert a counter device into the machine to operate it, there is an option for this on the 3501i. The service manual lists the items for the option necessary to install the option. If you are referring to just a mechanical counter there is no such option.
