Lines on prints
  • brancas
    • Jul 2009
    • 78
    Lines on prints
    Hey guys. I have an FS C8520 giving off black streaks. Transfer belt was changed. A few months after problem reoccured. Transfer belt is the issue. What can cause the transfer belt to give that problem. I do not have a sample now to show. But u can see the same pattern on the printed docs as well as the belt. Irecently installed a used working belt and it worked for a few weeks. I also changed the drum and the black developer which was looking worn. Any suggestions?
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Re: Lines on prints
    check your waste toner coming out of the transfer belt and to the bottle.
    • tee
      • Aug 2014
      • 79
      Re: Lines on prints
      I have seen this a few times.
      It is the waste toner drive assembly gears failing.
      PARTS PIPE TRANSFER CLEANING ASSY SP (302K09404_)
