KM3035 compatible drums?
  • axyun
    • Aug 2007
    • 1323
    Does anyone have or is anyone aware of compatible drum available for KM3035. Just changed drum unit and caused small scratch on drum 3/4 inch long and want to save as much as i can to to correct problem.Frank
  • patrickjlc
    • Feb 2015
    • 223
    Re: KM3035 compatible drums?
    Drums from the km-2530, 3530 will fit
    Sent from my SM-G930V using Tapatalk
    • axyun
      • Aug 2007
      • 1323
      Thanks Patrick but wouldn"t I still need to buy whole assembly and pay $abou $300. I was wondering about just getting drum and changing only that in unit
      • patrickjlc
        • Feb 2015
        • 223
        You might try getting just the drums, but have to get some with a review. I bought some from a seller and were complete crap, 6 drums to the garbage. Would not hold toner
        • patrickjlc
          • Feb 2015
          • 223
          Does it show too much? Is the people using the machine complainy? If not, get some nail polish and paint over the scratch (clear) It would print blank instead of the black scratch..... untill you get a replacement drum.
          • JR2ALTA
            • Feb 2010
            • 2030
            I was thinking if the scratch is on the front or rear, Frank could flip the paper landscape and it wouldn't show.
            • axyun
              • Aug 2007
              • 1323
              Thank you Patrick + JR for 2 great responses. The customer has called and would prefer to not see the scratch mark. I have investigated aftermarket
              drums thru alibaba and was skeptical and your experience, Patrick, has convinced me not to do it. The nail polish is a wise compromise as scratch is
              edge of page .
              Jt, I don't know why I did not think of your obvious and brilliant solution. The scratch starts at edge(rear of machine) and comes down no more than an inch. So rotatating the paper to 8 1/2 x 11R woule take the scratch out of the imaging area. So I think I will do both. Use a bit of nail polish on scratch and rotate the
              paper. Thanks again guys
