TASKALFA 5551ci-Error 5102
  • niyaskarimba
    • Sep 2014
    • 110
    [Error Code] TASKALFA 5551ci-Error 5102
    Dear All,
    We are getting an error code C5102 in one of our Task Alfa 5551Ci machine.
    Already tried to update the firmware to the latest version & also replaced drum & charge roller Unit.
    But still same.
    Kindly advice us a possible solution.
    Thanks in advance
    Regards,
    Niyas
  • Midhun maliyil
    reliable tech
    • 4
    Re: TASKALFA 5551ci-Error 5102
    try to reset the charge roller count !!!!!!
    • niyaskarimba
      • Sep 2014
      • 110
      Cleared,but still same..
      Thanks for your reply
      • Kyo fan
        • Dec 2013
        • 368
        If replacing drum unit C and charger didn't help, the next thing is high voltage pwb. Re seat connectors on it, check contacts, and replace it if nothing changes.
