Task alfa CS-6002i S001 on U412 after installing maintenance kit
  • bustertech
    • May 2011
    • 9
    [Error Code] Task alfa CS-6002i S001 on U412 after installing maintenance kit
    After installing a maintenance kit, I went into workflow (U952) & performed all adjustments without incident until U412. After scanning the density print (with 20 sheets over top), I got S001. I went back & performed U464 again, got the same result, went back & cleaned the front & rear ID sensors but get the same result. Has anyone else experienced this? Thanks.
  • Kyo fan
    • Dec 2013
    • 368
    Re: Task alfa CS-6002i S001 on U412 after installing maintenance kit
    Make sure the optical section is clean.
    • darry1322
      • Oct 2010
      • 817
      Make sure your paper is in the tray straight and all print alignment has been done. Lead edge, trailing edge, centering .... etc.
      • Geo
        • 660
        Yep.what darry1322 posted. Most of the time it's an image misalignment to the paper.
        • sparkycivic
          • Apr 2017
          • 348
          platen glass underside, and scanner mirrors need to be clean for this to work.
          tap the lid button and observe the lamp... foggy glass?
          remove glass and use cellphone lamp near CCD, look down at carriage: is phone lamp clear?
