Twain driver kyocera
  • Moshie
    • Sep 2017
    • 9
    [Misc] Twain driver kyocera
    have a customer that's using the twain driver to scan into their app. when scanning its perfect, when they printing 2 pages are released, when the page is full of info, is the info on the first page and the last two lines on second page. when the page is not full it will print on the first page and the second page will be blank
    tried from 3 other scanners Epson, hp, canon, didn't happen
    kyocer 5002i latest firmware
    Re: Twain driver kyocera
    what are they using now?
    PC or MAC?
    usb or enet?
    so many Q's so little info!
    • Moshie
      • Sep 2017
      • 9
      windows 7, Ethernet
      • Moshie
        • Sep 2017
        • 9
        PC or MAC?
        usb or enet?
        windows 7, over the Ethernet
          ok ...
          WHAT PROGRAM ARE THEY USING?
          • Moshie
            • Sep 2017
            • 9
            Umedex
            It's based on the browser. This app isn't installed on the PC
            Umedex - OCTANE(R) Application Suite for Mobile Health
            • Santander
              • May 2009
              • 768
              From your description, it appears to be a mismatch in paper sizes. Just like when you go to print a receipt from a webpage and windup with two pages instead of one because the webpage exceeds the letter size. I would check the Twain driver settings for paper size. I would also make sure that the ADF feed [which I assume you are using] is not slipping creating a slightly longer page length.
              • Moshie
                • Sep 2017
                • 9
                Thanks for your response. I did check the paper size and it's letter.
