KX driver vs XPS
  • BabblingXombie
    • Jun 2015
    • 32
    KX driver vs XPS
    Whats the difference between a KX driver and a XPS driver?
  • darry1322
    • Oct 2010
    • 817
    Re: KX driver vs XPS
    Use XPS drivers when printing XPS documents (never) and KX for everything else.
    XPS is a format developed by Microsoft to compete with PDF.
      • 30086
      Never install the XPS driver use the KX driver
      • justanotherhack
        • Apr 2015
        • 74
        XPS driver is something Micro$oft kludged together to make ID10T installs easy. Causes memory issues, XPS errors, and other wierdness. Even though it is listed in Kyocera's downloads, DO NOT USE IT. Use KX (without xps) driver, unless you are installing in a location where CITRIX is used, then use the PCL uni driver.
