DF-7110 jam 6510
  • nathicana
    • Aug 2008
    • 332
    DF-7110 jam 6510
    This 5052ci with DF-7110 jams intermittently with a 6510.04.86.01.03, a DF exit sensor stay jam.
    Jams indicate paper is feeding from drawer 4. Drawer 3 has the same paper loaded in it. I would have expected some 6510.03 jams. Maybe they are equally likely to happen if that drawer is used.
    Destination is tray A, the stapling output tray.
  • kba
    • Feb 2010
    • 10
    Re: DF-7110 jam 6510
    Any update on a fix? I have the same issue.
      with about 10 months that have passed and seeing who the OP is.. I doubt you will get a fix.
      • nathicana
        • Aug 2008
        • 332
        Here is what worked for me.
        It was recommended by Kyocera to one of our field techs.
        The finisher came into the shop and I installed the new style bundle eject switch and wiring.
        There is a lot of disassembly.
        • kba
          • Feb 2010
          • 10
          Thank you for your help!
            how long did it take for you to solve this?
            why no report back on the fix until now?
            • nathicana
              • Aug 2008
              • 332
              I think I did this job in June of 2019.
              The fix works for J6511 jams on the DF-7120 as well, they are basically the same thing.
              I posted my solution in a thread started by someone else about this problem. DF-7120 J6511
              It is difficult getting the bundle eject section in and out of the machine, and there is a trick to putting the belts back on the side registration unit where the new style switch and wiring are installed.
              The job took me several hours, give yourself a lot of time.
