P2040dw 0150 EEPROM data error
  • StratManDan
    • Nov 2018
    • 96
    [Error Code] P2040dw 0150 EEPROM data error
    Hi Guys,
    I have a Kyocera Ecosys P2040dw on my bench that was showing a "call service 0150" EEPROM data error. I replaced the Main PWB and the EEPROM. The "0150" call service code returned. I reseated all the connectors, but the code still returns.
    Any suggestion as to the next step to take?
    Thanks!
  • rigthejig
    • Jan 2015
    • 14
    Re: P2040dw 0150 EEPROM data error
    Hi I had several kyocera 4200 printers throw up this code ,each one had a spurious toner fitted, when Kyocera toner was fitted, the problem magically disappeared, I'm told it was a batch of faulty chips in the toner cartridges, worth a look.
    • StratManDan
      • Nov 2018
      • 96
      Originally posted by StratManDan
      Hi Guys,
      Thanks!
      I'll look at the toner cartridge, and try a new one. Thanks!
      • StratManDan
        • Nov 2018
        • 96
        I tried a different toner cartridge, and inspected the contact points, which appear to be okay. The error still returned.
