SMB v2 problems
  • pjr60
    • Oct 2013
    • 7
    SMB v2 problems
    The latest security upgrade for windows 10 defaults to SMB v2.. This has caused problems with a few of the printers out there. What is an easy fix?
  • granata
    • Jan 2012
    • 32
    Re: SMB v2 problems
    Unfortunately the solution is to set smb v2 / v3 on mfp, if available, or set scan to ftp
    • copiertec
      • Jan 2016
      • 2205
      Re: SMB v2 problems
      SMBv2 should not affect your printers, as all printers are on IP or usb connections, and do not scan. So if you are having issues printing to your printers it may be something else such as virus protection added to your PC.
      • Scottb
        • Apr 2013
        • 306
        Re: SMB v2 problems
        maybe this will help
        • Sayens
          • Mar 2013
          • 17
          Re: SMB v2 problems
          Remove windows security patch KB4408960, and/or KB4480970.
          • HenryT2
            • 962
            Re: SMB v2 problems
            Try this : Go into the Windows Apps and Features section to ' turn features on / off ' . Scroll down to SMB and turn SMB1 back on .
            "The Serenity Prayer" . . .
            God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
            • guitar9199
              • Sep 2016
              • 1100
              Re: SMB v2 problems
              That's really not a good idea. SMB v1 is a security flaw that Micro$oft closed for a reason. Reopening that hole could open YOU or your company up to a lawsuit if the customer suffers a data breach from it.
              If worse comes to worse, configure FTP scan, or scan to email for the customer.
                Re: SMB v2 problems
                Thank You Sir, All these folks giving advise to re enable SMB1 are NOT giving good advise and like you said... " Reopening that hole could open YOU or your company up to a lawsuit if the customer suffers a data breach from it. "
                I have been pressing this response since the problem arose. SOME just don't get it...
