Kyocera 4551 error F124
  • bryant28282000
    • Jul 2012
    • 145
    Does anyone know what F124 means, I dont see it in the service manual. THX!
    Re: Kyocera 4551 error F124
    google is your friend
    SOLVED: Kyocera TA4551 getting F124 every time it recovers - Fixya
    • bryant28282000
      • Jul 2012
      • 145
      You must not be a technician because google is not always your best friend. If you read that post it saids cancel energy save, I did that and it still after 5 sheets gives system error F124. I also upgraded the firmware
      • Santander
        • May 2009
        • 768
        F12x codes are definitely in the service manual and provide six steps to correct the scan problem, not an energy saver problem. Make sure the connector from the DP to the machine is properly seated then follow the other steps. You said you upgraded the firmware, did you use the full firmware upgrade or the turbo pack? We do not use the turbo pack as any corrupted files are skipped it only compares the file name and date and if it is the same it skips over-writing it, the full firmware upgrade while taking longer will over-write any corrupted files. My guess is you either have a loose connector on the harness from the DP to the machine or that wiring harness is defective. Hope this helps.
        • bryant28282000
          • Jul 2012
          • 145
          Thank You for that information and yes I found the DP board not fully seated from moving the copier. I appreciate that advice!!
          • bryant28282000
            • Jul 2012
            • 145
            To anyone with that F124 code, please check the connection between the DP and DP Board. What would happen because the DP board was not fully seated after 5 copies it would throw this code. I press on that small DP board and sure enough it went down about 2mil.
              been in the industry for 31+ years.. Certified by many of the major brands... look at my rep power vs yours.
              YOU NEVER MENTIONED WHAT YOU DID/TRIED. You asked for help... I gave what I found quickly.
              That will be the last time.
              YOU ASKED FOR HELP. FU
              • bryant28282000
                • Jul 2012
                • 145
                I have also been in the industry for 30 yrs and to state google is your friend is not only a unnecessary statement but it makes the person asking the question as if they are dumb. I love the expert advice on Copytechnet but for someone thats been in the industry your answer was stupid. Your expert advice in pointing me to google but fix ya which states to turn off power save. Sometimes its better to stay silent, if you dont know instead of leading the blind to the end of the river.
                Who cares about your rep power!
                • Santander
                  • May 2009
                  • 768
                  As I explained in a PM to you if you don't agree with a suggested solution, just ignore it! Who cares about rep power? I do, as that person has provided many good solutions to problems and while none of us have all the correct solutions, a user with a higher rep power has provided more correct solutions to problems than not. It actually pains me to have provided you with the solution to your problem and now to have you flame on someone trying to help whether correct or not is unconscionable. You were in diapers when I started in this industry, but give me a rep power of 50 versus a rep power of 0, I will take the 50 any day. Consider your self blocked by me, you do not deserve any support, you are an idiot!
                    Thanks Brother.. You are correct if we had all the answers we'd be engineers... not the ones that figures how to fix their fuck ups in the field!
                    • bryant28282000
                      • Jul 2012
                      • 145
                      I don't need your senseless help. You two brag about providing many solutions, Someone please give them a fucking Grammy. I am so honor to have gotten advice from the most brilliant experts. Thank You, Mr. Expert for referring me to Fix ya!!
                      • ntbann
                        • Jan 2012
                        • 628
                        bryant28282000 you are a DOUCHEBAG sir!
                        • logrady2331
                          • Feb 2011
                          • 301
                          [QUOTE=bryant28282000;723279]You must not be a technician because google is not always your best friend. If you read that post it saids cancel energy save, I did that and it still after 5 sheets gives system error F124. I also upgraded the firmware[/QUOTE
                          Just had a TA 3051ci pop up with an F124 code when put into low power. Checkked DP board and sure enough the pcb wasn't properly seated. remedied the problem. thankyou.
                          • Jhn16
                            • Sep 2019
                            • 7
                            Almost f errors goes to memory issues on kyocera. So if the machine connected on the network make sure all pc printer q is empty
                            Make sure date and time is current.
                              NT... fret not..
                              look at his stats 103 posts.... -=0=- rep power
                              this isn't the first time HE has responded to folks in that manner. I have had his entitled whiny ass on iggy ever since he made his FIRST post and responded in like fashion ...
                              I let guys like this post their crap and I don't usually respond.
