Scan to folder error, an odd one, and an old one
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Everything is setup right. But just couldnt get it to work.
    Series: Falcon 3
    OS: Win 7
    Windows Event Viewer gave this: "server was unable to allocate from the system nonpaged pool" everytime there was attempt to scan. Time stamp matches both end so Mr Google was recruited to investigate.
    This is what fixed it:
    Source: srv
    Event ID: 2017
    Level: Error
    The server was unable to allocate from the system nonpaged pool because the server reached the configured limit for nonpaged pool allocations.
    Some research led me to find this Google Groups discussion about the problem and this Microsoft Technet article discussing the solution (look at the bottom of the page). Apparently you need to tell Windows that you want to use the machine as a file server and that it should allocate resources accordingly.
    HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\LargeSystemCache
    HKLM\SYSTEM\CurrentControlSet\Services\LanmanServe r\Parameters\Size
    Original Post --> Windows 7 Nonpaged Pool Srv Error 2017 | alan.lamielle.net
    The usual disclaimer, apply this info at your own risk.
    Idling colour developers are not healthy developers.
  • francisco
    • Nov 2009
    • 168
    Re: Scan to folder error, an odd one, and an old one
    Series: Falcon 3
    OS: Win 7
    Source: srv
    Event ID: 2017
    Level: Error
    Microsoft Update Catalog
