TASKalfa 406ci- Faded prints- C5101 error code and other 76xx codes
  • Alexkyocera
    • Jul 2015
    • 82
    Replace Drum, DV, Main Charge, interchange Laser unit, transfer belt. Nothing works anyone had the same problem??
    Re: TASKalfa 406ci- Faded prints- C5101 error code and other 76xx codes
    what are the counts on parts BEFORE replacement? and now?
    did you clean the whole machine?
    what do the contacts for those items looks like? Clean? Straight?
    did any values on bias get changed..?
    toner supply tubes clogged?
    does this unit have xfer roller on door? was it replaced? cleaned? contacts?
    more info please...
    • RobertOB
      • Dec 2018
      • 26
      We had a machine do this in our shop, Kyo had us replace just about everything in it, earning the machine the "Million Dollar Machine" Turns out there was some bad wires in a wiring harness, Get your meter out and start checking, took one of our techs about 2 days to check every cable in the system, but the machine is now back out in the field and working great for a few months now.
      • masterchill
        • Jul 2005
        • 100
        We had a machine do this and found we had to rerun the transfer belt setup. We did a 952 minus the counter reset for the setup selection and all came back to normal.
        • Alexkyocera
          • Jul 2015
          • 82
          thanks for the feed back
          • john1
            • Nov 2016
            • 6
            clear the charge counters on the machine and you will never have this problem, if you dont clear the counter when replacing these it will cause this all the time
            john
            • Alexkyocera
              • Jul 2015
              • 82
              john
              Need that, changed all major parts, only thing left to try is replacing the High Voltage board
              • pascalb.
                • Aug 2016
                • 47
                Hello,
                I agree with John.
                if the Main charge counter is higher than the Drum counter we have a C51XX
                Good day.
                Do not lament,
                do not mock,
                do not hate,
                but understand.
