kyocera mita fs 6525 mfp
  • smiley
    • Aug 2008
    • 616
    good day guys. the copier indicate unknown Toner Installed. PC. we want to used compatible toner for this machine. we already replaced toner chip. but it gave us same result. thanks.
    there is no glory without sacrifice
    Re: kyocera mita fs 6525 mfp
    replaced chip with WHAT?
    that shows the maker of the toner didn't put a proper chip in
    • smiley
      • Aug 2008
      • 616
      replaced it with new toner chip. but got the same result.
      • Bix
        • Apr 2018
        • 1421
        Perhaps a correct chip has not been chosen or is not programmed right. Try another.
        • Geo
          • 662
          DON"T DO IT......Compatible toner has issues..
          • ntbann
            • Jan 2012
            • 627
            Just had one this morning. Background all over page. Cause? Junk Inovera aftermarket shit toner! Never use knockoff in a Kyo!
            • Ctl-Alt-Del
              • Jul 2006
              • 430
              The machine seems to be WAD (working as designed), that message is telling you that aftermarket toner is installed so if you want to get rid of the message put a Kyocera toner in the machine. Whatever you're doing with a "toner chip" is a waste of time and any savings your seeing by putting aftermarket toner in a Kyocera will be gone halfway through your second or third toner cartridge when you'll be forced to replace your developing unit and possibly a drum. BTW, the use of the aftermarket toner is saved in the machine and indicated on the status pages so the developing unit you'll be replacing no longer has warranty coverage.
              I've been working on Mita and Kyocera equipment since sometime in the last Century and they don't like aftermarket toner. Other manufactures generally have shorter life drums that end up getting replaced before shitty toner has a chance to kills them.
              Happy Friday.
              • Geo
                • 662
                "I've been working on Mita and Kyocera equipment since sometime in the last Century and they don't like aftermarket toner. Other manufactures generally have shorter life drums that end up getting replaced before shitty toner has a chance to kills them."
                "since sometime in the last Century"...Why did you have to word it that way...Now not only do I feel old, I am depressed...
                Have a great weekend everybody...
                  "OH but I save SOOOOOO much Money!" how many times have we heard that line...as we're doing a 300-500$ repair DUE TO SHITTY COMPATIBLES?
                    BUT.. we ARE getting older! Our advantage ( being old farts ) we are able to THINK and ANALYZE the problem...
                    the people coming into the industry today,can only "go by the book", they never studied the THEORY for the different sections of the machine. And they seldom want to take advise that "doesn't fit the book".
                    NP I will take it to the grave...their loss.
