Duplex Error
  • irrlight
    • Jul 2025
    Duplex Error
    Hello, I have a problem with the kyocera 2035 printer.
    Setting the duplex option to none is not saved.
    When I put it as the none option, after the configuration is saved and closed, when I go to open again it is horizontal.
    It always stays in this option even when configuring.
    I'm using ubuntu, it was working normally but started to display this error of not getting fixed the option.
    I thank the attention.
    Sorry for my English.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Duplex Error
    Ubuntu has a very helpful feature called CUPS (Common Unix Printing System).
    Open an internet browser, and type localhost:631 into the address bar and press enter. Here's a walkthrough to help you get the rest of the way.
    change default printing settings - Ask Ubuntu
    • copydocinc
      • Mar 2015
      • 263
      Re: Duplex Error
      If you are on a windows 8 or 10 operating system and using their stock driver, you might want to go to the Kyocera web sight and use the drivers there. I have noticed a lot of window drivers, especially window 10, have issues.
