Scan software
  • Leebs14
    • Feb 2014
    • 457
    Scan software
  • kuby
    • Oct 2007
    • 1414
    Re: Scan software
    Have you talked them into getting Pin Point scan. You can scan to email, documents, desktop, folders, on a user coded input tried directly the pc they use. (logged into)
    • mincopier
      • Dec 2015
      • 289
      Re: Scan software
      Pin Point scanning is great when it works. Make sure to get version 3 otherwise you can not browse any sub folders. A warning on the scan to email with Pin Point scan. It does not scan to email directly. It sends the file to the computer where it opens the default mail app and the file is an attachment.
        • 30554
        Re: Scan software
        KYOCERA Print Center
        KYOCERA Document Solutions Inc
        Utilities & tools
        KYOCERA Print Center is a utility app that supports KYOCERA printing devices and scanning devices that share a network connection with Windows 10 devices. The app is primarily a scan driver and a device monitor. It also includes a library of printable templates and a camera
        KYOCERA Print Center is a utility app for KYOCERA printers that share a network connection with computers or tablets running on Windows 10 or later. With this app, you can do the following: - Discover and monitor KYOCERA printers - Scan documents, capture images, and extract text using Optical Character Recognition (OCR) - Select or create lined templates to print - Configure advanced print settings for KYOCERA printers - Specify folders in Driver Library that advanced print settings can access for watermark images, driver profile files, and saved printouts
        • ntbann
          • Jan 2012
          • 632
          Re: Scan software
          Utilities & tools
          https://www.microsoft.com/en-us/p/ky...ot:overviewtab
          I looked on the new kyo site and dont see any reference to print center.
          • FriendlyTech
            • Jan 2018
            • 30
            Re: Scan software
            it's in the Microsoft store, free download. Works great. Only available for Windows 10 though.
            • ntbann
              • Jan 2012
              • 632
              Re: Scan software
              Thanks. Found it. Its like the mobile print app. Not real practical for a office. Take document to the machine. Then back to desk. Then scan. Then back to machine to pick up document. Then back to desk. Too many thens!
              • JVergin
                Service Tech / IT Rep
                • 216
                Re: Scan software
                Another option is scanning to a USB drive. plug it in to the copier, scan to it, take it back to the computer and retrieve the scan.
                I've also heard of people plugging a USB drive into a router and setting it up for SMB scanning. I haven't had any luck with this myself at the office, but im pretty sure it's a glitch in the firmware of the router.
                Pinpoint scan is OK. I would like it better if there was an option to just automatically populate a list of available computers to scan to rather than using a pin.
                Could also setup a custom box, and have the customer download it from the copier's web interface.
                  • 30554
                  Re: Scan software
                  Why can't they use scan to folder and import the file?
                  • kuby
                    • Oct 2007
                    • 1414
                    Re: Scan software
                    You can setup Pin Point scan to scan to a folder on the network drive that is shared.
