Staple waste box is full
  • djs9164
    • Mar 2018
    • 79
    Just saw this message on a Taskalfa 8002i. The firmware is current. Anyone else. The staples were empty. Maybe a firmware bug?
    Sent from my XT1635-01 using Tapatalk
  • Scott
    • 196
    Re: Staple waste box is full
    WOW that's a new one
    • ntbann
      • Jan 2012
      • 628
      I've seen piles of staples in those finishers. Maybe the machine knows more than the engineer?
      • Geo
        • 662
        I'm wondering...Do you have a hole punch unit? If you do and you change the word punch to staple , it would make sense. Perhaps the firmware got the words transposed.
        • djs9164
          • Mar 2018
          • 79
          I have confirmed this issue on 2 other 8002. Both had latest firmware. Looks like a bug.
          • DavePo
            • Jul 2008
            • 305
            I have it also on 2 7002i's with DF7110. Hotline wasn't helpful. Ordering staple unit and finisher control pwb.
            • djs9164
              • Mar 2018
              • 79
              I wouldn't replace anything. It's definitely firmware. Just updated a 6002 and it did not have this issue. Reported to my Kyocera rep.
              • sparkycivic
                • Apr 2017
                • 348
                Might a punch hole be caught under the punch unit(optical sensor facing down toward hole waste container) and typo in firmware saying staple?
                I catch myself mixing up staple and hole punch in my speech all the time
                • rigthejig
                  • Jan 2015
                  • 14
                  Had the same problem when a new 8002i ran out of staples, customer replaced staples and waste staple box full appeared, downgraded firmware and message disappears, definitely a bug in the latest version of firmware ver.4.03.0030.
                  • DavePo
                    • Jul 2008
                    • 305
                    Fixed both machines with the message by also downgrading firmware. Have 1 stapler that is bad however, now doesn't recognize staple present. Awaiting replacement.
                    • djs9164
                      • Mar 2018
                      • 79
                      Confirmed by Kyocera. There is a flaw in the latest firmware fo the 7002 and 8002 that will cause this message to appear when out of staples.
