copystar 2530 acting weird
  • garrycmsi
    • Jun 2015
    • 22
    [Electrical] copystar 2530 acting weird
    hello techs,
    I have a old cs2530 doing weird things I have never seen before on this mode, first the copy quality is grainy and secondly it will just turn off and back on by itself ? I am wondering if anyone has seen this problem
    Thank You
    Re: copystar 2530 acting weird
    Originally posted by garrycmsi
    hello techs,
    Thank You
    well since you have given us soooooooooo much information to help you..
    good luck with your problem.
    we are not mind readers!
    • garrycmsi
      • Jun 2015
      • 22
      wow! Phil B is somebody having a bad day? the copies have a distinct grainy look like fine wood fibers most notably in large solids.then randomly it will click go off and come back on by itself without turning off or on the main switch manually I didnt realize this was so hard to understand. any ideas would help.
      Thank You Everybody
        Thank You Everybody
        No.. not a BAD day .. just LACK of information such as:
        Page counts on drum/dev unit.
        Does it WIPE off or is it bonded well to the page?
        Type paper n weight?
        Is it humid in the room?
        What page count on fuser?
        It is kinda tiring to have to pull TEETH to get info from "techs".. IF they EVER called a tech support help desk.. They would be asked those SAME questions...
        Sooo
        Are you a Tech?
        • JR2ALTA
          • Feb 2010
          • 2030
          It's gotta be 15 years old. Let it die, man.. just let it die.
          You're losing developer bias. You likely need a high voltage board. See my first thought for permanent fix.
          • garrycmsi
            • Jun 2015
            • 22
            Thanks Phil B, it only has 109,000 copies.yes it is fused, 20# bond, no humidity.seems to have electrical interference like a corona arch or some high voltage leak.
            Thanks Everybody
            • garrycmsi
              • Jun 2015
              • 22
              I would but you know the story nonprofit no money.
              • copyaction
                • Oct 2007
                • 985
                The interlock switches on the left side would be suspect, as well as the transfer roller, drum, developer unit and the main charge corona.
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5007
                  hello techs,
                  Thank You
                  You can share this wonder with us and post a pic.
