3253 Jamming in PF 6110
  • djs9164
    • Mar 2018
    • 79
    Jam is intermittent,more often than not. When feeding using tray 4 the code is 1614 and tray 3 it's 0533. Already tried new bridge drive unit and pwb for the PF7110. The trays 1 and 2 have no problems. Any feedback appreciated.
    Sent from my XT1635-01 using Tapatalk
  • djs9164
    • Mar 2018
    • 79
    Re: 3253 Jamming in PF 6110
    Title should be jamming in PF 7110.
    • Tonerkiller
      • Oct 2012
      • 665
      That is a multifeed jam. did you adj the sep pressure?
      • djs9164
        • Mar 2018
        • 79
        Yep. Like ai said even swapped out the bridge unit from another machine
        • darry1322
          • Oct 2010
          • 817
          Swapping out the bridge unit isn't the same as adjusting sep pressure though. Just so we're clear on what has been tried.
          • djs9164
            • Mar 2018
            • 79
            Yes I tried the sep. pressure in every position. And the bridge unit I swapped is working today n another machine. On this unit the rollers are all part of the bridge unit.
            • mita
              • Sep 2010
              • 87
              QA_H102_2ND_0055_SB.pdf This is from the 2 series but may still be relevant to your issue
              • mita
                • Sep 2010
                • 87
                Here is the QA
                • djs9164
                  • Mar 2018
                  • 79
                  Originally posted by mita
                  Here is the QA
                  I have seen that too in a report but my unit is way past that this one doesn't even have the polystyrene washers thanks anyways
                  • darry1322
                    • Oct 2010
                    • 817
                    Just wanted to be clear on the sep pressure. Using a different bridge unit might still have the default sep pressure setting (you know, since the rollers are all part of the bridge unit) and still have jamming issues unless adjusted. Different paper stocks might need different settings for sep pressure. I've solved a few multi feed jam issues by reducing sep pressure a notch.
                    • djs9164
                      • Mar 2018
                      • 79
                      Went out today with a swapped PF 7110. Found the switch arm in the vertical TX unit was sticking. No reason so I swapped units. All is good. Thanks for the help.
