Kyocera M5521CDW Error code: C4600
  • miketw
    • Jun 2019
    • 2
    [Error Code] Kyocera M5521CDW Error code: C4600
    Hello,
    I have a Kyocera Ecosys M5521CDW. Since 3 days it it has an Machine Failure, with Error code: C4600.
    The advise that was given to me was; 'buy a new one, because it is not worth to repair it'. Well, the printer is only 2 years and 4 months old, so i hope you guys can help me a little bit futher.
    What I do know: The error code C4600 stands for LSU Cleaning motor error.
    Before I just buy a new one, is there anyone who can help me with this error code?
    Thanks! Mike
  • djs9164
    • Mar 2018
    • 79
    Re: Kyocera M5521CDW Error code: C4600
    Remove the connector from the main board for the cleaner motor.
    Sent from my XT1635-01 using Tapatalk
    • miketw
      • Jun 2019
      • 2
      Thank you for your quick reply. Is it possible to give me an indication where it is located on the main board? See attaches picture.
      Thanks in advance!
      • djs9164
        • Mar 2018
        • 79
        [ATTACH=CONFIG]42807[/ATTACH]
        Thanks in advance!
        Need to look at a manual tonight. Should be a small 2 pin connector.
        • djs9164
          • Mar 2018
          • 79
          This made me more than in non-tech can handle. The boy that controls it is called the container relay board it's located on the right hand side of the machine it's a long narrow board. The connector you need to disconnect is y c 13 it is a two pin connector. Good luck
