Kyocera Ecosys M2540 error F330
  • Ricky965
    • Mar 2008
    • 36
    Paper runs through the doc feeder but nothing else when I try to copy. Get this error F33C
    Will print the menu map etc. It's when you make a copy it gives the error.
    Pulled the fax card but it didn't change anything.
    I mistyped the error code in the thread line. It's F33C. I pulled it from the event log to be sure.
    Did a maintenance code 21 on it and it went back to work. Thanks for reading.
