Fleet Services customer deleted
  • kuby
    • Oct 2007
    • 1411
    I know how to set up a New customers is Fleet Services, but a account got deleted that has already been set up and registered with machines. Is there a way to add this account back and use the old access code and make the machines show up or am I going to have to reinstall with a new code and go to each machine and that it off Fleet Services and add it back in with a new Access Code?
  • kuby
    • Oct 2007
    • 1411
    Re: Fleet Services customer deleted
    Found the solution, Thanks.
    • GeneOR95
      • Feb 2018
      • 161
      Can you share the solution in case someone else runs into this problem?
      • kuby
        • Oct 2007
        • 1411
        Switch from Devices to Administration. When in Groups if you look at the far right you will see Recycle Bin. Click on that and restore the account.
