Any one know if you can change the Fax transmission speed from the Command Center on a 5550ci?
If so how?
Also I could not locate the Area in which to disable WSD Print. If someone could point me in the right direction for this one too I would appreciate it.
FYI when you open up the Command Center it looks like all the other Kyoceras I have but when you go into systems settings it is completely different.
Thanks in advance
If so how?
Thanks in advance
