Kyocera FS-1135MFP Fax help?
  • LilSnoop40
    • Jun 2019
    • 4
    question, i don't know how to send receive a fax. i have contacted the people at Kyocera and they weren't very helpful. i have the printer at my house, it was in an office before probably that had a dedicated fax line. now that the printer is at my house i have 1 line but there is a fax number and a phone number attached to it. not sure what that is called, but currently i have a brother printer and when a fax comes through with the line from the wall plugged into the line on the brother printer/fax it works. if i remove the line that is plugged into the brother fax and put into the Kyocera printer/fax in the line spot on the back or top nothing happens. the people at Kyocera said plug the line in and that's all i have to do but it doesn't work. but if i plug it back in the brother they were able to send a fax with no issues. i am wondering if there is a setting i have to do but they can't tell me?? hopefully someone else can.
    thank you
    • 29599
    Re: Kyocera FS-1135MFP Fax help?
    DRPD (distinctive ring pattern detection) – A fax feature that can detect a distinctive ring (one phone line can have two phone numbers assigned to it, each with a distinctive ring) and answer only on select rings.
    RX Setting Select the reception mode.
    Value: Auto (Normal), Auto (FAX/TEL), Auto (Answering Machine), Manual,
    Auto (DRD)
    If Auto (DRD) is selected, select the DRD Pattern.
    Value: Pattern 1 (Normal Ring), Pattern 2 (Double Ring),
    Pattern 3 (Short-Short-Long), Pattern 4 (Short-Long-Short)
    DRD reception mode is available for some countries.
    1 Press the System Menu/Counter key.
    2 Press the  or  key to select [FAX].
    3 Press the OK key.
    4 Press the  or  key to select [Reception].
    5 Press the OK key.
    6 Press the  or  key to select [RX Settings].
    7 Press the OK key.
    8 Press the  or  key to select the desired receiving
    mode.
    9 Press the OK key. Proceed to the next step if you
    selected [Auto(DRD)] in step 11.
    10 Press the  or  key to select the DRD Pattern.
    Pattern 1 Normal Ring
    Pattern 2 Double Ring
    Pattern 3 Short-Short-Long
    Pattern 4 Short-Long-Short
    • LilSnoop40
      • Jun 2019
      • 4
      bsm2 - you are very help. is the DRPD feature a setting i must set first since he has (one phone line can have two phone numbers assigned to it, each with a distinctive ring) and answer only on select rings. one of the phone numbers is the home number and the other number is fax line. so i will set it to DRD following your instructions above. how do i know what ring pattern to setup. i thought he told me now when the line is hooked up to his brother fax it goes ring, ring pause 3 times.
      hopefully my questions aren't dumb as i have no idea what i am doing when it comes to the fax side of this machine. all the other functions no issues.
      Thank you
        • 29599
        Thank you
        Contact your phone company they will provide you the ring pattern that they use
