Taskalfa 3050ci complete page is dark
  • qwertz-support
    • Jul 2019
    • 3
    Hi everyone,
    i have a Kyocera Taskalfa 3050ci, which prints the complete page dark. Does anyone already had the problem? Thanks
  • Happy Copier
    • Mar 2019
    • 49
    Re: Taskalfa 3050ci complete page is dark
    Originally posted by qwertz-support
    Hi everyone,
    What does the status page look like when you print it?
    Sent from my SM-G930V using Tapatalk
    • Santander
      • May 2009
      • 768
      Hi everyone,
      The example you provided is not dark, it has a speckled background. I would start with running the laser cleaning in systems mode, dev cleaning, and a calibration cycle. If you still have the problem then you would need to look at the cleaning of the transfer belt. Is the transfer belt cleaning brush rotating normally, is the waste toner auger operating properly? The sample you provided is from March, is the unit still exhibiting the same problem?
        • 22801
        maybe give us counts on consumables?
        maint cycles counts?
        • Alexsiskm
          • Sep 2018
          • 11
          Do you use OEM toners or some Alternatives, refills?
