KM-2050 C6400 error
  • selig67
    • May 2008
    • 156
    KM-2050 C6400 error
    any ideas on alternative problems other than whats explained in the service manual?
  • techman
    • Dec 2007
    • 49
    Have you already tried running a 1087 1087 sub code 163 if so then i sugest you replace the fuser if that dont help start testing your boards cause your having a fuser problem
    • Dave10
      • Jul 2008
      • 197
      Every time I have seen this problem, it has been associated with a power problem. If the customer had a power outage, u163 will reset the code. Check the voltage in the customer outlet . If it shows less than about 108V under load, the power is the problem. If none of this works and replacing the fuser doesn't work, it's probably the engine board.
      • vikingmita
        • Nov 2008
        • 163
        -fuse in 'powerboard blown'. just trace cable from fuser.
