3051ci Jam 4019
  • tech07
    • Aug 2008
    • 409
    [Jamming] 3051ci Jam 4019
    This copier was giving multiple J40xx jams which was resolved by replacing the entire right conveying door unit. At the same time I replaced the bypass unit also with a brand new one. All jams were resolved except one.
    Jam 4019. Struggling with this one. Jams occur after cardstock passes registration sensor. It stops midway thru the fuser. Only when using the bypass. Made sure loop sensor values were correct with new door. This one seems to be stumping me. Any suggestions guys ?
  • ntbann
    • Jan 2012
    • 628
    Re: 3051ci Jam 4019
    We have one in our shop that is doing the same thing. The funny part is if you tell the machine that it has anything but but card stock it will feed the card stock. As soon as it is set to card stock 4019 occurs.
    • Tonerkiller
      • Oct 2012
      • 668
      Re: 3051ci Jam 4019
      There is that guide on the machine side by the reg sensor. Sometimes it gets bent. take it off straighten it and put it back on.
      • ntbann
        • Jan 2012
        • 628
        Re: 3051ci Jam 4019
        Its not a bent guide. If I put card stock in the bypass and leave the setting to plain it will feed the card stock all the way through the machine. Set machine to card stock and 4019.
        • Santander
          • May 2009
          • 768
          Re: 3051ci Jam 4019
          Have you checked the settings in U51 for loop detection?
          • tech07
            • Aug 2008
            • 409
            Re: 3051ci Jam 4019
            Yes. New setting came with chart with new door
            • 20gaugeO/U
              • 557
              Re: 3051ci Jam 4019
              This sounds familiar but would have happened years ago on a 3050ci flavor... Firmware fixed I believe
              Or what happens if you change the paper weight of Cardstock to something different? Or change Custom 1 to the same weight setting as Cardstock, does it jam or a higher weight???
              • ntbann
                • Jan 2012
                • 628
                Re: 3051ci Jam 4019
                If it's set to say thick it feed all the through.
                • sparkycivic
                  • Apr 2017
                  • 348
                  Re: 3051ci Jam 4019
                  I'm thinking theres a weak clutch in the conveying (middle) drive section. Any rust back there??
                  • tech07
                    • Aug 2008
                    • 409
                    Re: 3051ci Jam 4019
                    No.. all clutches are new
                    • bush_tech
                      • Jul 2018
                      • 51
                      Re: 3051ci Jam 4019
                      I'd replace the entire rego assembly next if you've done the clutches and door
                      • sparkycivic
                        • Apr 2017
                        • 348
                        Re: 3051ci Jam 4019
                        What happens if you run regular paper using "Card Stock" settings... if it jams, then it's a timing problem. If it doesn't jam, then it's a mechanical issue.
                        • Mr2crazed
                          • Jun 2014
                          • 35
                          Re: 3051ci Jam 4019
                          Do you have a finisher installed? If so, I've seen the bridge unit (attachment kit) cause jams when paper is run through the machine at half speed. There are one way gears inside that get gummed up.
                          • Tonerkiller
                            • Oct 2012
                            • 668
                            Re: 3051ci Jam 4019
                            I forgot about this one, I have seen this before. Be careful when you take that drive apart.
                            • tech07
                              • Aug 2008
                              • 409
                              Re: 3051ci Jam 4019
                              I don't have a solution yet. But I will not give up until I do
