KM-4035
  • LNorris
    • Sep 2008
    • 645
    KM-4035
    see if you guys have had this one before
    i went to work on this june 2008. it is a rental so its been replaced and i've just now gotten some down time to work on it.
    when i went to work on it last year, it had a code 3100 (scanner carriage), after t/sing the thing, then it flipped a fuser code, 163 wouldnt clear it and put a new fuser in it...the machine died after a 4200 code .
    so, i've put a new lsu in it..comes up fine...make about 150 copies, the machine starts to reboot itself in the middle of copies, just power off and on...continuously. i get a firmware update into it..and it still does it...any ideas on this one? Kyocera tech support off today.
  • Jimbo1
    • Mar 2008
    • 845
    The main charge isn't arcing is it? That might give you some rebooting.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • vikingmita
      • Nov 2008
      • 163
      -and explain 4200. change charge or worst case whole drum unit.
      • LNorris
        • Sep 2008
        • 645
        4200 is LSU/polygon motor issue.
        seems the 24v is dropping when this occurs, i have a tech rep here helping me t/s this. he thinks there is something wrong in the power supply. i'll let you know what we find out.
        • Jimbo1
          • Mar 2008
          • 845
          If his last name is General he will probably find it.
          He's a good man, that guy!
          Cdr. William Riker
          • LNorris
            • Sep 2008
            • 645
            that would be him! he is down here setting up our new TaskAlfa as well
            • vikingmita
              • Nov 2008
              • 163
              <4200 is LSU/polygon motor issue.
              yep, but arcing of high voltage from unclean charge/bad drum unit will quite often give you same error msg. on the falcon-series. had tens of those faults. best case: clean charge, worst case: change whole drum unit. have not had one bad lsu ever on those machines
              • nnnggg
                C4200
                my case to chang charge block
                • bdove
                  Dont know if you have fixed this problem yet but the main charge needs to be replaced on the machine. If the drum is pitted then replace drum and charge and your problem will go away.
                  QUOTE=LNorris;54409]see if you guys have had this one before
                  so, i've put a new lsu in it..comes up fine...make about 150 copies, the machine starts to reboot itself in the middle of copies, just power off and on...continuously. i get a firmware update into it..and it still does it...any ideas on this one? Kyocera tech support off today.[/QUOTE]
