Mita 4090-C710 code-help??
  • motox852
    • Sep 2025
    I have a mita DC4090 with a C710 code ( toner sensor problem), Should I replace the toner sensor? Also which simulation on this machine was it that you use to cancel a service code? Thanks for the help, gotta back on this machine today!!
  • Dukem
    Binding Hopper
    Sounds like the recycling section of the toner hopper is binding up and more than likely has broken a gear on one of the toner motors. Does it make clicking or grinding noises? You'll need to vacuum and clean out the recycling section and replace the gear. Reseting the disable function (It's been a while but I think it's sim 96) won't do anygood on this code. Just opening the front door or turning machine off/on resets code 710.
    • motox852
      Thanks for your help!!
      • motox852
        Didn't see any gears broken, cleaned out the hopper, and still as the paper get to the drum, I get a C710 code, any info??
        • cboucher
          • Sep 2025
          I don't know if you already tried this, but check the inside of the gears connected to the toner drive motor. Sometimes they can be cracked on the inside, causing the gear to skip on the shaft.
          • higherlevel
            • Aug 2006
            • 30
            Simulation 96 reset Codes on this machine...
            • kyoceradude
              The Great Gazoo
              • Aug 2006
              • 442
              When does the code pop?
              Are you saying the machine does not give the code until after paper feeds and is past the reg roller?
              My mission here on Earth is to help all you Dum-Dums!
