Kyocera KM-2530 How to Save Scanner Settings
  • ToddS
    • Sep 2019
    • 8
    [Misc] Kyocera KM-2530 How to Save Scanner Settings
    Forgot how to save "Scan to PC" settings so that user does not have to reenter preferences such as: PDF, Resolution, Continuous Sending, etc. each time a scan is performed. Everything works perfectly except these typical settings are not saved after the first scan, everything reverts back to the defaults. The saving of the settings used to work, must have been setup when the machine was new. Any help would be greatly appreciated.
    Thanks,
    Todd
  • DougMoney
    • Feb 2017
    • 70
    Re: Kyocera KM-2530 How to Save Scanner Settings
    Address Book. Create an entry and put your settings in there.
      • 30435
      Falcon 1 Needs to upgraded ASAP
      • denden4h
        • Mar 2006
        • 31
        The easiest way is to use the web interface to set the defaults.
        • ToddS
          • Sep 2019
          • 8
          Thank you denden4h!!
          I got the problem solved in 10 seconds!
          ToddS.
