taskalfa 300i
  • kashif
    • Apr 2013
    • 45
    [Error Code] taskalfa 300i
    kyocera taskalfa 300i is giving error code F335, can someone helpout
    Re: taskalfa 300i
    that would be in the service manual
    what have you done to fix?
    • JPazy
      • Jul 2019
      • 30
      Re: taskalfa 300i
      i don't think older machines have many F codes explained in the manual. Sounds familiar to a code i had once on a KM-3060 in which the ADF cable had gotten damaged and had to be replaced. You may want to check the connection of the cable between the ADF and machine.
        • 30294
        Re: taskalfa 300i
        Try updating the print driver should be kx driver set to pcl5
        or you can change the PDL to KDPL
        • jper34
          • Sep 2011
          • 225
          Re: taskalfa 300i
          you can try service mode #930,execute,,see if that works..just a shot in the dark..good luck,
          le use know what you find..
          Jaime
