FS-6530mfp out of memory
  • Rlcdrew
    • Dec 2018
    • 21
  • JPazy
    • Jul 2019
    • 30
    Re: FS-6530mfp out of memory
    have you tried turning off "RAM Disk" under the system menu? It reserve blocks of memory for features such as Private Print and Job Box. Remember to turn it off on the Print Driver as well.
    • 20gaugeO/U
      • 557
      Does the machine also have a Fax installed? Shutting the machine off with the switch should fix the error, sometimes these machines just get confused if they are never shut off (used as a Fax always on)... the memory is cheap, put it in and crank up the RAM setting in the System Menu - System settting
        • 30240
        Machine already comes with Memory (std/max) Standard: 1 GB RAM
        what's the status page show?
        • Rlcdrew
          • Dec 2018
          • 21
          It does show 1gb ram
          • ntbann
            • Jan 2012
            • 628
            Try changing driver to pcl5c.
              • 30240
              Odd problem replace the 1 gig
              with a good one and try
              • Rlcdrew
                • Dec 2018
                • 21
                Unfortunately this ram is built onto the board as far as I can see
                • Santander
                  • May 2009
                  • 768
                  Have you checked the status of print jobs? Is there a print job that has not printed and using all the memory? The ram memory is shared between copy and print and if you have a print job that is hung up for whatever reason and is using up all the memory it will affect the ability of the unit to use memory for copy jobs.
                  • Rlcdrew
                    • Dec 2018
                    • 21
