306ci adf dog earing original
  • Tonerkiller
    • Oct 2012
    • 669
    I know this sounds like an easy one, but we had this feeder all apart and have not figured out why the lead edge towards the front has a fold on the corner. It is a small fold 3 to 6 mm. I did the registrations, took the feed head off and did not see what it is hitting. This feeder does not have a sensor that tells that it is down, no exit sensor either, so I ran it with the feeder lifted and it does not do it between the feed tire and glass. Has anyone else encountered this.
  • ntbann
    • Jan 2012
    • 631
    Re: 306ci adf dog earing original
    I had a broken hinge pocket once.
    • Tonerkiller
      • Oct 2012
      • 669
      I did take the hinges off to see if they ware broken. They were not.
      • lees
        • Apr 2011
        • 95
        Take a look at bulletin H068. This may help with the issue. We have seen this a few times.
        • Tonerkiller
          • Oct 2012
          • 669
          WOW, nice. That looks like it may be the solution. I searched Astea, bit I searched for "dog earing" nothing came up. Search for "dog ear" and it comes up. Thank you. I will post the end result.
