TA 6002i low memory
  • j2shortt
    Learning to speak PCL...
    • Feb 2019
    • 54
    [Error Code] TA 6002i low memory
    Good morning, I have a customer who is getting a "low Memory" error.
    Ive never seen anything like this. Any suggestions on what it could be or has anyone else seen this on this series? i did a search and came up with a post here same thing on a 4002i.. got some insight, but would like to reask for some fresh ideas. Thanks in Advance!
  • nathicana
    • Aug 2008
    • 328
    Re: TA 6002i low memory
    Here's something to try:
    If remote services are turned on unplug the printer cable and restart the machine. Then go into maintenance mode 520/ on off configuration. Set to off and restart machine again.
    This will turn off remote services. No need to do anything on the KFS website if you use this procedure. You can turn it back on later if you want in the web interface.
    • j2shortt
      • Feb 2019
      • 54
      I updated the firmware, and that took care of it.
