Windows 10 and scan Kyocera ecosys M5526cdn
  • varazir
    • Nov 2019
    • 2
    Hello,
    I have a 3rd party software that I try to use to scan from this printer. I get a error check TWAIN drivers in the controlpanel.
    The settings looks OK there. The correct printer is selected.
    It's documentation system so it need to be used to scan with, can't use any other.
  • ntbann
    • Jan 2012
    • 628
    Re: Windows 10 and scan Kyocera ecosys M5526cdn
    We had a twain issue that we had to right click and run as administrator.
      • 30219
      Did you configure the twain driver? Also have seen issues where Kyocera twain will not work with some software.
      • varazir
        • Nov 2019
        • 2
        tried it now, one step forward, windows scan finds the printer but can't connect to it.
        • rvptor
          • Aug 2018
          • 19
          Update new firmware on M55256cdn...
