Kyocera Ecosys M3540dn
  • Brandon
    • Jun 2019
    • 72
    [Error Code] Kyocera Ecosys M3540dn
    Good day
    i am sitting with an Ecosys M3540dn that is giving me a cassette error on the display , the paper tray is not lifting the paper at all , any suggestions or assistance would be appreciated
    thank you in advance
  • Luther
    • May 2006
    • 682
    Re: Kyocera Ecosys M3540dn
    the paper tray lifts as you push it in,on the bottom of the paper tray is a white plastic piece that contacts the metal bar on the base of the machine, bend the base up slightly to contact the bottom of the tray to make the tray "pop" up
    • Brandon
      • Jun 2019
      • 72
      Thank you for your reply , the issue was the gears on the sub frame shafts are broken so the lift motor cant lift the tray
      • craigster
        • Apr 2016
        • 201
        Are your sure that is a 3540? 3550/60 has the lift motor.Not a fun fix!!
        • ntbann
          • Jan 2012
          • 628
          Put a paper tray in from a 3540. Better than tearing whole machine apart.
          • Brandon
            • Jun 2019
            • 72
            will try thank you for all the replies
            • sparkycivic
              • Apr 2017
              • 348
              just have to mod the spring loaded tray slightly using knife to make it fit into the copier, otherwise works perfectly, no lift motor needed, no 4 hour ordeal to swap broken parts...
