Help with Kyocera compact Flash diagnostics
  • dstar
    • Mar 2009
    • 6
    [Misc] Help with Kyocera compact Flash diagnostics
    I have 4 FS-9530s under service that I need help creating a cf diagnostic disk to adjust the fuser for one machine to run permaseal jobs. The other three work fine. I have the drive(8MB), I formatted it on the 9530, and I have the files. I have tried extracting the zip file to the root directory. I cannot get diagnostics to show. Can someone tell me what the location of the files are? Do they go in API? or root? I tried just about every combination.
    Thanks in advance.
  • drazen7777
    • Sep 2010
    • 40
    Re: Help with Kyocera compact Flash diagnostics
    Hy
    Files go to the root(folders) , than you search in menu maintenance option and Enter it from menu.
    Poslano sa mog SM-N960F koristeći Tapatalk
    Technician -- a person who fixes the mistakes made by engineers.
    • dstar
      • Mar 2009
      • 6
      I copied the files in all folders +root and it works.
      Thanks for the response.
      Cheers
