taskalfa 3500i light image.
  • Gab
    • Aug 2015
    • 656
    Image is too light. Toner new and OEM . I execute u132 it works for 1 or two days and then the same.
  • copiertec
    • Jan 2016
    • 2184
    Re: taskalfa 3500i light image.
    What is the count on Drum, Developer? We need more information.
    • ntbann
      • Jan 2012
      • 623
      An image of what it is doing would help too.
      • Tonerkiller
        • Oct 2012
        • 665
        Sounds like the dev is bad.
        • Gab
          • Aug 2015
          • 656
          copier has made about 180k copies.
          The image is too light practicly no image.
          • Mr2crazed
            • Jun 2014
            • 35
            Also check that EcoPrint isn't enabled.
            • rey
              • Feb 2015
              • 11
              clean the laser mirrors
              • rapo_tech
                • Feb 2019
                • 114
                Maybe you r running out of toner. Feel the cartridges if there is toner.
                I had similar problem with TA250CI. The chip showed like 50% toner left but actually the cartridge was empty.
                Also could you try U910. My colleges are saying it also helps improving print quality.
                They say it clears some other settings also beside print coverage. Although i have not had a chance to try it myself.
