CS-3511i command center password reset
  • Old Crow
    • Aug 2011
    • 203
    Hi guys, so I installed an off lease CS-3511i yesterday and the customer's IT guy cannot login to the machine. I had him try 3500/3500, Admin/Admin and admin00. Are we using the wrong info. or I'm thinking because it's a used machine that previous owner changed the default password. I have seen some posts about entering prescribe commands but I am not familiar with this as I usually am dealing with Ricohs.
    Short of performing a memory clear in service mode and re-entering all settings, is there an easier way? Or, are we just using the wrong login info?
  • GeneOR95
    • Feb 2018
    • 161
    • Old Crow
      • Aug 2011
      • 203
      Re: CS-3511i command center password reset
      Thanks so much for the information, I will be going there tomorrow to give that a try. Will let you know how it goes and not to worry, I won't be sharing the info. with the customer.
      • Old Crow
        • Aug 2011
        • 203
        FYI, this worked like a charm...thanks for sharing this!
        • GeneOR95
          • Feb 2018
          • 161
          Glad it worked for you.
