Kyocera "bulletins"
  • JR2ALTA
    • Feb 2010
    • 2033
    Kyocera "bulletins"
    I am sick and tired of getting burned by Kyocera's bullsh** bulletin access. I bang my head against the wall, ordering parts only to find out there's some "QA" buried inside their Internet Explorer Only portal. Nothing in the portal is labeled. You literally need to open every f'n one of them. These are real problems, real money and real time wasted. And, yes I opened a ticket, and no they didn't tell me there was a QA. They probably can't find them either.
    /rant
  • Scottb
    • Apr 2013
    • 306
    Re: Kyocera "bulletins"
    I'm with you brother....
      • 30203
      Designed in Japan
      Built in China
      Tested in USA
      • mincopier
        • Dec 2015
        • 289
        You can do a search and narrow it down a little. Fully understand the problem. Another link of theirs warned me about using IE to access abut the Portal does not.
        • Santander
          • May 2009
          • 768
          What happened to the days when Kyocera would push out email notifications of new Tech Service Bulletins? Now even if you log on to the website and go to downloads and select technical-bulletins it does not even list service bulletins! Is there some secret code I am missing? They have to do better!
            • 30203
            Mita or Kyocera never like to issue bulletins they hide them in QA
            Mita Mylar is the Answer
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              /rant
              When TA4500i first came out, the fuser was just outright garbage as the heat roller coating would wearout prematurely all the frekin time**. (amongst the garbage overtoning developer, Its not remedied, but when it first came out...it was frustrating as new stuff usually are, i'm looking at YOU HP)
              I went to the portal as one would... took forever to find the QA as "premature failure" and "marks" wasnt the keyword.
              "fuser Staining" was.
              And lonnnnng time ago, there was a change to the Transferbelt to the C3232e as the original design didnt have those "spur gears"...that took forever too...just to prove to higher ups that was the cause for some jamming.
              **the problem with ALL KYOCERA fusers is they dont count idle time in fuser life. Early fuser failure is usually due to long idle time. But then on higher speed machine if you have short time to low power, you may burn out the pressure engagement motor on the fuser itself from activating frequently... nice design...
              Idling colour developers are not healthy developers.
              • JR2ALTA
                • Feb 2010
                • 2033
                Thanks for sharing. My recent frustration was the 3252ci paper trays were randomly switch from letter to statement. Ordered sensors, boards. Turned out to be cassette modification in a QA.
                Mind you nothing was broken or unusual about the cassette that i could've detected, just a redesign they kept hidden.
                • copiertec
                  • Jan 2016
                  • 2205
                  /rant
                  I thought it was just me, apparently I'm not alone according to the responses.
                  • Mr2crazed
                    • Jun 2014
                    • 35
                    I ran across the same problem and took a lot of digging to find the solution.
                    • Scott
                      • 196
                      Glad to hear I am not the only one having problems with site, finding a parts/service manual is tough. I find it easier to just google it and save time.....geeezzzzz
                      • tsbservice
                        Field tech
                        • 8010
                        Hey guys, don't underestimate the power of access to manufacturer's tech site. I'm giving my best and a half, arms and legs to have it, with no luck. Using backdoors helps for some time but not indefinitely.
                        I invested a lot of my free time to search for any slice of useful information I can find in KM tech site.
                        I used to use Toshiba tech site many years ago and it was very good and informative - BSIs, Espos/RIBBON and so on. Maybe Kyocera screw mightily techs on easy of access of their web tech site...at least I've heard Kyo are joy to work on
