taskalfa 5500i
  • Gab
    • Aug 2015
    • 676
    taskalfa 5500i
    I received a load of second hand copiers . I checked an TA 5500i with 770 finisher. PAper jam about 10cm after fusing unit . It looks that finisher attachment kit doesn't rotate. I asked my provider and told me that alla machines has been checked.
    Any idea?
    • 30508
    Re: taskalfa 5500i
    you can do a 906 in sim mode will reset any trouble code
    • tsbservice
      Field tech
      • 8056
      Re: taskalfa 5500i
      Finishers are easy to be damaged during transport. Anything broken or missing? Maybe relay unit unplugged?
      • Scottb
        • Apr 2013
        • 308
        Re: taskalfa 5500i
        Jam codes are your friend...
        Also Kyocera is discontinuing parts for the model at the end of this year...
        • gregrcs
          • 22
          Re: taskalfa 5500i
          Does it jam every time ? If not, check for flat spot on sep. rollers. If it does, is the paper tray programmed to the wrong size ?
