Wondering if anyone has seen this issue on these internal units.
When the customer staples it goes through the process you here it staple but it does not. When you pull the unit out you see the staples all over inside between it and the punch unit. The only error code is on it is C8800.
Which I realize is the connector from DF to machine and I see there is a bulletin that address that problem. Paper come out straight when exiting.
