Taskalpha 3050ci parts compatibility
  • sostek
    • May 2010
    • 80
    Does anyone know if the paper feed assemblies from a 4551ci will work in a 30/35 ppm taskalpha as the roller replacement is much easier.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Taskalpha 3050ci parts compatibility
    Do mean from 4551ci to 3050ci the 3050ci is a older machine
    Regards Mark
    • sostek
      • May 2010
      • 80
      Yes to 3050ci, its older but PF assemblies are very close mechanically ecxept for the sep roller. Have some extra time and might give it a try.
      • craigster
        • Apr 2016
        • 201
        The 3050ci has the older feed assy. 4551ci came with the newer feed assy, which are interchangeable with newer firmware. I stock those for the reason they are easier to replace feed rollers.
        • Scottb
          • Apr 2013
          • 308
          the 3501/3051 will be backwards compatible with the 3500/3050 units
          the 45/5501 and 45/5551 will be backwards compatible with the 45/5500 and 45/5551 units
          A 45/55 series will not work in a 3050 3051 or 3500 3501 due to the clutch pack in the back of the machine. the 30/35 copy machines have two fewer clutches in the pack
