Kyocera P3155dn password
  • GeorgeBest
    • Jul 2009
    • 525
    Hi,
    I'm installing this printer from box.
    Entering the date and time needing a username and password,
    now for this model it is 5500/5500, it works . . .
    But when I'm entering the printer using webinterface again it askes for a login name and password
    5500/5500 is now NOT working, anyone a clue here ??
    first time, none experience in this model
    and is there a way to disable the login on the display?
    thanks in advace
    gr George
  • Kyocera_77
    • Dec 2013
    • 7
    Re: Kyocera P3155dn password
    Originally posted by GeorgeBest
    Hi,
    thanks in advace
    gr George
    Username : Admin
    Password: Admin
    Στάλθηκε από το Mi 9T μου χρησιμοποιώντας Tapatalk
    • GeorgeBest
      • Jul 2009
      • 525
      Thnx for reply
      Can I disable the login on the display ??
      Thanks in advance
      Originally posted by Kyocera_77
      Username : Admin
      Password: Admin
      • Kyocera_77
        • Dec 2013
        • 7
        Thnx for reply
        Thanks in advance
        No, you can't.
        But you can add any Username and Password you like from command center.
        • GeorgeBest
          • Jul 2009
          • 525
          Looked, I can indead adjust the Admin/Admin
          but not the 5500/5500 login on the display ?
          Maybe overlooking?
          gr George
          No, you can't.
          • Kyocera_77
            • Dec 2013
            • 7
            Maybe overlooking?
            gr George
            Tell me what you want to do...
            5500 code is from manufacture
            Admin is a code that you can change it on command center if you want.
            • GeorgeBest
              • Jul 2009
              • 525
              What I want is to disable the 5500/5500, but that is not possible as you said
              very annoying for the customer . . .
              • Calliem
                • Jul 2015
                • 14
                Hi,
                thanks in advace
                gr George
                !R! KSUS "AUIO", "CUSTOM:Admin Password = 'admin00'";EXIT;
