taskalfa 5500 i
  • Gab
    • Aug 2015
    • 671
    taskalfa 5500 i
    At first machine when printed some PDF files printed 2 pages and stoped .With other PDF have had no problem (i have a post about this problem|) but now it doesn't work at alla . It stucks at Welcome and after several minutes error F000 appers . I try to get in program mode (10871087)but io could't! From old posts about this code i have to upload firmware, or replace ram or HD problem. Can it be something else (copier is at some distance and i have to be prepared) ? Can i swap ram from other ta5500i and if yes i have just to teplace it ?
    Where can i find firmware foe this machine?
    • 30213
    Re: taskalfa 5500 i
    Be sure to load the kx driver and try changing emultions
    Do any updates from Adobe if that's what there printing from.
    • Scott
      • 196
      Re: taskalfa 5500 i
      lean toward HDD
      • craigster
        • Apr 2016
        • 201
        Re: taskalfa 5500 i
        Yep! I had the same issue on a 3050ci and HDD resolved that.
        • Gab
          • Aug 2015
          • 671
          Re: taskalfa 5500 i
          You mean to format it?
          Also where i can find firmware for this model?
          If i swap ram from an other machine , is there any problem ? (in case i try id memory is the problem)
          • Gab
            • Aug 2015
            • 671
            Re: taskalfa 5500 i
            Before the HD i want to try to load Firmware (some techs told me that the problem is at firmware). They send the firmware via email but when i put flash in and turn on the machine, no loading firmware and after some minutes error appears.
            I have formatted flash with fast and regular format , no result.
            Any idea why it doesn't load firmware?
              • 30213
              Re: taskalfa 5500 i
              What print driver are you using and emulation
              • kuby
                • Oct 2007
                • 1403
                Re: taskalfa 5500 i
                Is the firmware in a Zip file? If so you need to un-zip the file and then copy the contents over to a flashdrive to the root directory and try it again. Also you need the full firmware and not the turbo pack.
                • Gab
                  • Aug 2015
                  • 671
                  Re: taskalfa 5500 i
                  KX driver
