Resetting Printer to Factory settings using Prescribe
  • copyman20
    • 207
    Hi all
    Does anyone know the Prescribe command that resets the controller of Kyocera printers back to factory?
    Re: Resetting Printer to Factory settings using Prescribe
    Why dont you network it, reset to factory defaults from the rui and then format the hdd.
    Sent from my SM-G960F using Tapatalk
    • GeneOR95
      • Feb 2018
      • 161
      Originally posted by copyman20
      Hi all
      !R! ACNT "EGRE";EXIT; resets the admin account pass word
      !R! EGRE; EXIT; will reset the engine board.
      • copyman20
        • 207
        Thanks for the reply.
        I am trying to find a way to remove the KFS access code that is currently on the printer. I have tried re-initializing from the web-interface, i have tried the Prescribe "INIT" command, "EGRE" command. No Go. These commands look like they just reset the FRPO values to default but not reset the device to completely.
        If this was an MFP, this would be very easy with U520. But this printer doesn't have an equivalent mode.
        Thanks again.
        • GeneOR95
          • Feb 2018
          • 161
          Thanks again.
          This is dependent on whether it is registered to your company account or another companies account. If it is another company you will have to contact them to delete it from their account. The alternative is to contact Kyocera, prove that it is now your device and have them remove it.
            What printer model ?
            • rstarr
              • Aug 2011
              • 9
              Use gateway for windows
              • copyman20
                • 207
                Ecosys P2135dn
                  Hi
                  I found this in the service manual it seems the easiest way to go and prints an error log.
                  Now with this working try
                  echo !R! FRPO INIT; EXIT;
                  turn power off/on
                  • GeneOR95
                    • Feb 2018
                    • 161
                    Ecosys P2135dn
                    Harry,
                    You have still not indicated whether it is on your company's KFS account or on another company's account. If it is on your account then your company's KFS administrator can go in and delete it then download the DRDT tool to unregister the printer. If it is on another company's account you are at their mercy unless you can get Kyocera to delete it. I have taken all the training on KFS and there is no other way to remove it. I have verified this with Kyocera. They are adamant about this as a security feature.
                    • copyman20
                      • 207
                      Originally posted by GeneOR95
                      Harry,
                      After getting frustrated with this printer. i tried your suggestion with the DRDT tool. At first it didn't work, then i sent the "INIT" and "EGRE" commands again. once i turn it back on I was able to turn off "Remote Services".
                      A few months back we had a device that was on our KFS account that was returned to a leasing company. I had deleted the device from group (customer) that it was in. However, whoever bought the device from the leasing company put it on a network and the device popped up on the group that it was in originally in (real weird).
                      I'm trying to avoid that situation.
                      Thanks for the help
                      • GeneOR95
                        • Feb 2018
                        • 161
                        Thanks for the help
                        Sent a PM followup
