P6035 - Removing drum units.
  • rdyjnkns
    • 135
    [Misc] P6035 - Removing drum units.
    I'm in the process of cleaning the interior of a P6035. I have the service manual, so I was able to remove the toner cartridges and transfer belt. My problem is with the drum units. Facing the unit, you can lift the right side, the left side (where the gear is) will not be lifted. Is there a step they left out of the manual? Any assistance would be deeply appreciated.
  • dschultz31
    • Aug 2018
    • 33
    Re: P6035 - Removing drum units.
    On the left side of the transfer belt is a grey cap with a screw and a drive release lever under it. That's under page 4-8 in the manual. Other that that... I'm not sure what else would hold you up.
    • rdyjnkns
      • 135
      Thank you. I found it.
