Light copies for TA 4500 and 3500
  • Gab
    • Aug 2015
    • 671
    These machines have almost the same problem . The copies are light. I cleaned optics, charge roller at both machines At 3500 i swapted developer unit and charge roller with no result. At 3500 i execute 132 and works fine for about 300 - 400 copies and then light copies . At 4500 i have to execute 130, 132 and also darken the density to have acceptable result. But after some copies , light toner.
    Toner is genuin also both machines under 200k copies. Any idea?
  • toddanderson
    • Dec 2005
    • 236
    Re: Light copies for TA 4500 and 3500
    Clean the inside of the laser
    • craigster
      • Apr 2016
      • 201
      I would try a new drum, even with only 200k on machine the unit is pretty old in years.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Try replacing with new oem parts as units when needs what's the life on pm
        Regards Mark
        • thish.csoffice
          • Jun 2020
          • 9
          If the density getting lighter as u are making copies it seems like the toner hopper is not working correctly. Did u ever get an error code when copies are too light?
          If yes clean the hopping unit and clean all the sensors.
          Sent from my STK-L22 using Tapatalk
          • Bix
            • Apr 2018
            • 1421
            Clean PHUNIT
