Does TA 3500i TA 3550ci Paper feed assy interchange with a TA 4500 and 4550ci ?
  • Doug James
    • Jan 2012
    • 935
    It seems like when I replace the paper feed rollers on a 3500 or 3550ci it gives me problems. I hate those assemblies. Can you use the TA 4550 4500 paper feed assembly in a 3500i 3550ci with success. I am thinking about just replacing all these machines PF assy's when I get em. Thanks so much for any help !!!
  • Santander
    • May 2009
    • 768
    Re: Does TA 3500i TA 3550ci Paper feed assy interchange with a TA 4500 and 4550ci ?
    Originally posted by Doug James
    It seems like when I replace ther paper feed rollers on a 3500 or 3550ci it gives me problems. I hate those assemblies. Can you use the TA 4550 4500 etc with success. I am thinking about just replacing all these machines PF assy's when I get em. Thanks so much for any help !!!
    I have not tried it, but from just looking at the parts manual, the 4550ci has the feed shift solenoid the 3550ci does not. I doubt that the engine firmware on a 3550ci would support the feed assembly from a 4550ci, I would also suspect the wiring harness is different.
    • copiertec
      • Jan 2016
      • 2192
      They are different, the 4500i feed assemblies are motor driven, the 3500i are not, they are clutch driven.
      • JR2ALTA
        • Feb 2010
        • 2030
        Good news.
        I ordered a 302LC94040 feed unit assy and they sent me one that uses the easy clip style rollers. There may be a QA about a parts update (new pn 303NJ94110). I thought I ordered the wrong one but it fits and that godforsaken separation housing is gone.
        • Horologydoc
          • Jun 2011
          • 61
          Doug, they discontinued the low speed feed assemblies on these years ago. Even if you order the low speed they will send you the high speed feed assemblies for future reference.
          • Doug James
            • Jan 2012
            • 935
            THANKS SO MUCH !!! Huge help
